yz85 fowling plugs one a day
Old Apr 24, 2007 | 09:45 PM
biddog's Avatar
Default yz85 fowling plugs one a day
Ok no some one who has a yz85 2007 and he is fowling a plug Avery time he drives it what code be the problem with these his brother has a yz250 never fowled a plug since he had it and they had them for 4 months now.
Old Apr 24, 2007 | 10:12 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
If it's not premix, go to premix. If it's already premix, you might change your ratio OR your jetting is off.
Old Apr 25, 2007 | 09:31 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Does he lug it a lot?
Old Apr 25, 2007 | 09:15 PM
biddog's Avatar
Ok yes he lugs it allot in and out of the grudge and then he goes right on the road and then ya no what he dose next but I will drive his brothers yz 250 so I can keep up and most of the time we will have to double up and lay his dirt bike down because he stops and it bogs and fowls a plug and it is 8 dollars for one spark plug so he needs to find out soon.
Old Apr 25, 2007 | 09:58 PM
Raptorlegs's Avatar
T Rex Rider
Get a rag and some sand paper after the plug and they usually work as good as new. And tell him to wind it up every once in a while.
Old Apr 26, 2007 | 09:45 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
He doesn't have to buy those expensive plugs that the dealer sells. I run a $2.50 NGK BR8ES in my CR250 and it hardly ever fouls a plug and runs as good as any other smoker.
Old Apr 26, 2007 | 08:30 PM
TRX450Rrider's Avatar
the YZ 85 needs to be rapped out most of the time. It sounds to me like he's not used to operating a 2 stroke machine. Tell him to open up the throttle and slip the clutch when he slows down. If he is dropping RPM when slowing and turning and not using the clutch to keep the engine revved out, he'll blow through plugs. Make sure you're not sucking water when you go through the puddles too. Water getting into the filter and bogging down can cause your engine to lug when you don't want it to among other problems, thus causing your plugs to get all fouled up.
Old Apr 28, 2007 | 12:19 PM
biddog's Avatar
Well the dealer only sells the 7 8 dollar plugs nothing ales it the only dealer around and its performance so Avery thing is expensive and he chaps it pretty high rpms all the time but like wan I am on his brothers yz250 I can stop and weight for him then he will stop and shut it right of and then i will tern the 250 of I don?t get it there is something going on with the yz85 but I am running the 250 hard all the time then stopping.
Old Apr 30, 2007 | 11:31 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Don't get the plugs from a dealer, go to a Atuoparts store like Napa, or you can go to AutoZone and crossreference the plug.
Old May 2, 2007 | 07:38 PM
biddog's Avatar
he has got like 80 no joke in a box just sitting there
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
frostphase
Aug 19, 2015 07:11 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Captjay
Jul 23, 2015 12:33 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
