polaris sportsman starting question
Old Apr 25, 2007 | 10:37 PM
newguy07's Avatar
Default polaris sportsman starting question
Just bought my first ATV a few days ago. A new 2006 sportsman 450. I have a question about starting it. When I start it for the first time in a day it takes 3-5 attempts to get it started. This happens no matter what position the choke is in. It is also spring here so temps have been 60-70. My question is should it start up on the first try or should it take several attempts like it is?
Old Apr 25, 2007 | 10:45 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
If your starting it with the key(battery) it should start right up...........Never did start mine with the pull starter yet!!!!!!!...........I don't even use the choke now..........You may need to check to make sure the cable is not hung open a bit causing this trouble.........That's what it sounds like to me.........Caper.......
Old Apr 25, 2007 | 10:50 PM
newguy07's Avatar
Yes I am starting it with the key. Takes about 3-4 x cranking it. What cable should I check?
Old Apr 25, 2007 | 10:54 PM
Make sure your choke cable or in-richer some call it .....is not part way open........It should be pushed all the way in...........Just try to pull and push it and you can tell by feel if it's going all the way in and out......Start there first......Caper...........
Old Apr 25, 2007 | 10:56 PM
Any miles on the quad yet.....if there is.......Check the air filter too!!!!...Caper.........
Old Apr 25, 2007 | 11:17 PM
newguy07's Avatar
about 3 miles on it. filter is clean and clear. Where do I look for the choke cable. Just pushing and pulling the choke it seems to operate as it supposed to.
Old Apr 25, 2007 | 11:38 PM
with only 3 miles on it......I would wait an see if it is still doing this after a couple of good day rides!!!!!............I know the dealer changed over to a Champion Plug from NGK after the first 50 hour service..........He said the NGK would not hold up like the champion will......I still like NGK better.......so my next plug I may try the Factory spec. plug back in.......Caper........
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
Schneider
Jun 4, 2015 11:37 AM
May 27, 2015 11:15 AM
