Removing rear drive shaft
Old Apr 26, 2007 | 09:20 AM
yearmax's Avatar
Default Removing rear drive shaft
Hello all ,
Can anyone give me an idea of how hard it will be to remove the rear drive shaft on an 01 400 manual 4x4? What exactly will I have to remove ? I took the 4 bolts that hold the shaft to the motor but it seem that I may have to remove it from the rear as well. Can anyone help me here....
Thanks in advance
Eugene
Old Apr 26, 2007 | 09:55 AM
booboobear's Avatar
just wait for buckaroo hes usually running around here with the manuals lmao My 02 has 4 bolts in front and 3 in back, looks to me like you have to take them all out
Old Apr 26, 2007 | 01:30 PM
buckaroo50's Avatar
Originally posted by: yearmax
Hello all ,
Thanks in advance
Eugene
Get a big hammer. lol...
Old Apr 26, 2007 | 01:37 PM
buckaroo50's Avatar
Hello all ,
Thanks in advance
Eugene
Never done it. But I think I would take the 'C' clips out of the universal joint and take that apart, once the universal joint is out then you can slide the drive shaft out, once it is unbolted. Other than that you would have to take your differential or engine out. I don't think you want to do that.
Old Apr 26, 2007 | 01:42 PM
buckaroo50's Avatar
Hello all ,
Thanks in advance
Eugene
Opps, you are talking about the REAR drive shaft... looks like you take out the 3 bolts near the differential and the ones toward the tranny and it should fall in your hands....
Old Apr 26, 2007 | 01:43 PM
yearmax's Avatar
Thanks for the info ... I have the service manual but it did not show much about removing it. All I really need to do is replcae the seal for the rear diff. but it seems I have to remove the whole shaft to do so ..
I will check back later
Old Apr 27, 2007 | 12:19 AM
yearmax's Avatar
Well I worked on it some tonight and So far I had to remove the shock and link arms on one side to remove the shaft. Then I had to remove the 4 hex key bolts that hold the housing on so that I can get the seal out... Damn thing did not want to come out at all.. So far all is apat and cleaned .. Just wanting on the new seal to come in. Will keep you posted on my advanture.
Has anyone else had to replace this seal before ?
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
rcappie4
Jul 10, 2015 04:54 PM
cSchwartz
Jul 9, 2015 02:43 PM
Rider252
Jul 6, 2015 03:37 PM
