2000 500 Scrambler clutch on 1997 400 Scrambler?
Old Apr 26, 2007 | 09:48 PM
LawdogB2's Avatar
Default 2000 500 Scrambler clutch on 1997 400 Scrambler?
Will it work? Currently has blue spring and "stock" weights. My buddy already bought one and wants to use it. I didn't have a clue and have come to you all for help. My concern was with engagement RPMs and power loss at that speed. I don't figure that the 2 stroke has enough low-end power to get anything done at the likely engage speeds of the clutch. Thanks.
Old Apr 26, 2007 | 10:19 PM
ftwflh's Avatar
Basicly the clutches will interchange but you will need to have the right springs and weights for the bike.
The 500 has a blue/green spring with 10WH (47gram)weights.The 400 has a white spring(plain with a white end)and S55 weights.THe 400 will not opperate good with the 500 parts.
Old Apr 28, 2007 | 10:32 AM
drlang's Avatar
Is EBS an issue here?
Old Apr 28, 2007 | 07:21 PM
ftwflh's Avatar
Scramblers have no EBS unless it has been put on.
Old Apr 28, 2007 | 09:40 PM
drlang's Avatar
Well, it will bolt up and work. With that said, you'll need to change the inner components around. What is the reason for the swap anyway? Doc
scram5050
Aug 30, 2024 01:39 PM
robert301972robert
Aug 30, 2015 11:34 AM
scram5050
Aug 19, 2015 02:19 AM
Peter_
Jul 18, 2015 07:06 AM
