250x problems
Old Apr 26, 2007 | 09:54 PM
briz50's Avatar
Default 250x problems
how can i fix damaged treads on the head for the spark plug myself thanks, also i cant figure out why all of a sudden now when im ridding and i gun it the bike bogges down and will cut off if i stay on the gas.. any help would be helpful thanks
Old Apr 26, 2007 | 10:00 PM
bombrider04's Avatar
Well if you stripped it out I would try taking the cover off and tap the old threads if there is enough left so you can get the plug in....If it is too stripped out that you can't do so take it to a shop and have then redo the threads or buy a new cover...As for the bogging I would have to say that that is being caused by either the choke being on, low on gas, gas is shut off or you have clogged jets in your carb...If you have clogged jets then I would get carb cleaner and take the jetcs out and clean them and make sure you can see light through them...Hope this helps and any other ?'s let me know and welcome to the forums.
Old Apr 26, 2007 | 11:32 PM
briz50's Avatar
ok, thanks, what all do i need to do to re-tap it,, as far a taking stuff off, would i need to take the head off, also if not would it be ok to just do it like is and just hope debre doesn't fall in the motor
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
