Kodiak battery
Old Apr 27, 2007 | 09:32 AM
chambo10's Avatar
Default Kodiak battery
Hi guys, I was wondering what a reasonable price for a new battery would be? I have an 06 Kodiak 450.
Also, is there a trick to pull starting them like having them in neutral or somethig? Does the key need to be turned on or the choke on or off?
Thanks for any help.
Old Apr 27, 2007 | 11:15 AM
Cigz400's Avatar
It should not matter what gear it is in, however the key must be turned on and you may need to give it a little choke... i havent had a battery in my old polaris and been doing this for years... for your battery issue you can go to a walmart or something and get an ATV battery for about $40... They work just fine..
Old Apr 27, 2007 | 06:36 PM
chambo10's Avatar
Thanks for the reply. I have seen batteries on ebay for $60 but thought that was a bit to mich. Haven't tried starting it by hand so I wasn't sure if the gear or choke mattered.
Old Apr 28, 2007 | 09:04 AM
LoneViper's Avatar
When you go to start it, you need to get it up on top dead center or just over and give it a crisp pull. Dont pull it like your chain saw or you will wind up with a broken rope or wrist which ever gives first. When they fire they start pretty easy. I think the battreys are completly sealed, if it where mine I'd spend the extra $ and go that way again.
Good luck.
Old Apr 28, 2007 | 09:40 AM
chambo10's Avatar
I will give it a try. I am going to get another battery at some point, but I'll pull start it for now.
Old Apr 29, 2007 | 11:14 PM
desertgy128's Avatar
chamb10
You did not really pull start your 450 over a $40.00 battery? How did your batterty go bad so soon. I live in the desert and have 06 Kodiak also have drove the crap out of it and not even a hint of battery problems. Mayby you have another problem, lights dim? or even on? dirt in the switch, maby it needs a charge?? Try a couple of things b-4 ya throw in the towel and start hand starting.[img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img]
RedRancher
Oct 15, 2020 01:45 PM
txpedsrt1
Feb 3, 2017 08:07 PM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
