03 trailboss belt
Old Apr 30, 2007 | 09:18 AM
1999camaross's Avatar
Default 03 trailboss belt
hi
i bought a 03 trailboss used about 3months ago,when should you replace the drive belt,and how can you tell if you need to,the other day i thought that my bike didnt have the power it used to going up hill but i could not tell if the belt was slipping,also is it hard to change or should i have a dealer do it, wow thats alot of questions in one post
any help woul be thankfull
Old Apr 30, 2007 | 10:09 AM
scootergptx's Avatar
Supersock
Hired Gun!
Very easy to do. And just get a new one from NAPA. Muchy cheaper than the dealer.
When you ride, do you smell rubber burning? As for power, it's not a beast, but it should make most hills.
Old Apr 30, 2007 | 11:12 AM
no i dont smell any rubber.thanks for all your help
Old Apr 30, 2007 | 11:21 AM
campNride's Avatar
You can get the belts from NAPA. Didn't know that. Is it the true atv belt or is it a car belt? Good info to know because it is cheaper so I can have a back up. The belt is easy to change. Had mine off when I changed the clutch spring.
Old Apr 30, 2007 | 11:28 AM
Supersock
Hired Gun!
Best to take the old one in, they can cross the numbers off of it. But if you want to feel better about what it cost for a Polairs belt, go see what I'll have to pay for the wifes ds250. [img]i/expressions/face-icon-small-sad.gif[/img] Cheapest do far has been 74 plus shipping. [img]i/expressions/face-icon-small-shocked.gif[/img]
Old May 1, 2007 | 11:42 PM
TBJAY's Avatar
i have an 06 trail boss and when my belt got wet it slipped you know it because the engine revs up but you slow down.
Old May 2, 2007 | 09:31 AM
Supersock
Hired Gun!
If your belt does get wet, put it in nuetral (after you're out of the water) and rev it a bit. That will dry the belt, and you'll be good to go.
Old May 2, 2007 | 10:23 AM
campNride's Avatar
Depending on how much water you go through make sure you remove the little red plastic drain screw from the bottom rear of the belt cover. That will help get a majority of the water out and like stated earlier put it in nutrual and rev it for a little bit to heat it up inside and dry it. I was up in the northwest for a couple years and it happened all the time. Gets frustrating sometimes.
Old May 2, 2007 | 10:39 AM
Supersock
Hired Gun!
I fit happens all the time, it sounds like you need to check the seal of the clutch covers. They should be pretty watertight. Another place is where the snorkel hose connects to the cover. It's just held there by tie wraps, and they can be loose enough to let some water by.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Myronh
Sep 8, 2015 11:27 AM
