warrior won't stay running
Old May 23, 2007 | 02:35 PM
bamweiser's Avatar
Default warrior won't stay running
hey folks, my 93 yamaha warrior won't stay running .. checked the spark plug and it looks fine, going to change it anyways. it will start up but die right out afterwards .. sometimes it will staying running for a bit then die out. Sometimes i can rev it right up and it will stay running but eventually die out. check the gas hose to make sure it was getting air .. just cleaned the air filter. It started when i was running some big hills and jumping too. I worked the bike quite hard then at the end of our sess it started acting up. I also have an electrical problem. At first the negative connector was loose so i tightened it up and the neutal light would stay on but now i have to turn the key on then start it but this only works once, if i stalls i have to turn the key off then on again in order to start. anyways hope someone can help, its beautiful out and i can't ride [img]i/expressions/face-icon-small-sad.gif[/img]
Old May 24, 2007 | 07:48 PM
royiii's Avatar
I have a 92 warrior and after about 10 min of runing it dies. I think it might be the coil but I don't know how to check it. If you find out whats wrong with your's let me know. thanks
Old May 25, 2007 | 08:28 PM
bamweiser's Avatar
replaced coil, plug and carb still same problem .. think its the stator so instead of replacing it i am putting my other engine in
let you know what happens in a couple days
Old May 25, 2007 | 09:27 PM
bamweiser's Avatar
this site blows .. no one is nice enough to help out
Old May 27, 2007 | 03:48 PM
bamweiser's Avatar
oh and royii it was the CDI box
Old May 28, 2007 | 12:09 PM
Raptor450's Avatar
Sounds like you both have electrical problems. A problem I had with my Warrior one time was a wire going to the CDI in the back had rubbed the frame until the copper was touching the frame and grounded out. It would run for a while and then just die and wouldnt start back unless I shook the bike.
Old May 28, 2007 | 11:06 PM
royiii's Avatar
Thanks man I'll check it .<div class="FTQUOTE"><begin quote>Originally posted by: bamweiser
oh and royii it was the CDI box</end quote></div>
MikeyBoyesq
Nov 27, 2020 02:44 PM
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
jayking232003
Jun 9, 2015 02:54 PM
