How to drill a carb slide on a Hawkey (with pics)
I know a couple people including myself in the past wanted to know how to drill out a carb slide...
I made a quick page on how to do it. I did both of my Hawkeyes, and it helped.
http://www.swgrevolution.com/slide.htm
To be honest, I forget the size drill bit I used....
Just take your bits and see which one fits in the existing hole, then use that one. That's what I did.
I've done this mod several times, reason I ask about bit size was just wondering if anyone had drilled larger holes. On my Predators I went to two 1/8" vac ports but haven't tried that yet on a Hawkeye.....
<div class="FTQUOTE"><begin quote>Originally posted by: powerslider
I've done this mod several times, reason I ask about bit size was just wondering if anyone had drilled larger holes. On my Predators I went to two 1/8" vac ports but haven't tried that yet on a Hawkeye.....</end quote></div>
Hehe, seeing as it was my first time, I wanted to make an 'equal' hole on the opposites side. I'm not brave (nor experienced) enough to fiddle more than that.
I'm happy with the results I have.
