How to drill a carb slide on a Hawkey (with pics)
Old Jun 2, 2007 | 04:21 PM
powerslider's Avatar
Default How to drill a carb slide on a Hawkey (with pics)
Yeah I can't complain, pretty happy with the machine. I may get brave later on and try it....
Old Jun 2, 2007 | 07:56 PM
Grayb's Avatar
dont you lose downhill engine braking?
Old Jun 2, 2007 | 08:14 PM
TennesseeTider's Avatar
You don't lose engine braking in any way.
Old Jun 2, 2007 | 11:02 PM
00XJ's Avatar
Where did the spring, jet, and needle come from? Is it all under slide? Is the slide a solid piece, and the hole has to go all the way thru it? Is it aluminum?
Sorry for the questions but I want to know exactly what I'm getting into before I start. BTW, good review/pic's!
Old Jun 3, 2007 | 01:51 AM
  #15
Mickelonis1's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 00XJ
Sorry for the questions but I want to know exactly what I'm getting into before I start. BTW, good review/pic's!</end quote></div>
The Jet is in the pic, but this mod does not involve the jet in any way.... Ignore it.
The spring you will see as soon as you remove the cover. It is what sits in the middle of the slide.
The needle goes through the middle hole in the slide. When you pull the slide out, you pull the needle, spring, and nylon ring out.
Yes, the slide is a solid piece.
Yes, the hole goes all the way through.
I don't think it is aluminum, it seem to have a bit of weight to it, however I am not sure the material it is made out of. (it may be aluminum, but it seems a bit heavier to me).
As for the documentation, I'm sorry it is so "quick, down and dirty". I just didn't have time to go into too much detail. I'll re-do it soon and put more explanation to the steps.
Truly, this mod is a bit intimidating, but there's nothing to it.
I have heard rumors that Polaris actually did this to the later model Hawkeye's... I'm not sure the validity of that though.
Old Jun 3, 2007 | 10:22 AM
  #16
00XJ's Avatar
Thanks for the info. I've worked on motorcycle carbs before, just not CV carbs, so I'm somewhat ignorant about them.
  #17
00XJ's Avatar
Old Jun 4, 2007 | 03:40 PM
  #18
00XJ's Avatar
I began to look into drilling the slide, but found the air intake/breather tube for the drive belt I guess, is in the way. Am I correct in thinking the rear fender section has to be removed to allow me to remove this tube? I can't see anyother way the tube can come out.
Old Jun 4, 2007 | 07:19 PM
  #19
I began to look into drilling the slide, but found the air intake/breather tube for the drive belt I guess, is in the way. Am I correct in thinking the rear fender section has to be removed to allow me to remove this tube? I can't see anyother way the tube can come out.</end quote></div>
You would be correct =(
The whole rear end had to be taken off.....
You could just force the carb to the left a little bit (it's mounted by a rubber hose), but I found it easier to take the rear end off.
Old Jun 4, 2007 | 09:33 PM
  #20
00XJ's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Mickelonis1
You could just force the carb to the left a little bit (it's mounted by a rubber hose), but I found it easier to take the rear end off.</end quote></div>
Bummer....[img]i/expressions/face-icon-small-sad.gif[/img] IYO, are the performance gains really enough to warrant taking the quad apart?
