4x4 light flashing 500HO
Old Jun 10, 2007 | 01:51 PM
Dieselguy's Avatar
Default 4x4 light flashing 500HO
03 sportsman 500 (made 12/03, is this an 03 or 04?) the 4wd light flashs for less than a second in 2wd every now and then. what does this indicate? what repair manual is recommended for these machines?
thank you,
Old Jun 12, 2007 | 07:17 PM
Dieselguy's Avatar
Any thoughts on this at all?
Old Jun 13, 2007 | 01:16 AM
RticKwad's Avatar
Runs Stealth!
Well I post in the absence of others, I hear sometimes our Sportsman's
"Act up" whereby something is still reporting to be engaged in 4wheel/AWD.
I have heard about driving in reverse for so many minutes until disengagement.
You could let some others chime in here, as I have not had the problem and
only reporting what others have claimed. To be safe call your dealer or Polaris
and see if they confirm what I am saying or indicate some other problem.
Regards,
R'
Old Jun 13, 2007 | 07:28 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
has the hub oil been changed?
Old Jun 13, 2007 | 01:49 PM
RogerT's Avatar
I would start by checking the transmission switch. Sometimes they can become intermittent and make the bikes electronics think it is in a different gear, and thus turn off the 4wd, otherwise check the hub coils and wiring. Sounds like an intermittent problem. I am not that familiar with the 2003/4.
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
