Flywheel Puller
Old Jun 16, 2007 | 12:34 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Default Flywheel Puller
I have gone through 2 Ron Woods, who sells a heavy duty puller?
OMR
Old Jun 16, 2007 | 12:56 PM
Boomer84's Avatar
need to heat-up flywheel hub and then use puller ,will come off!
Old Jun 16, 2007 | 01:22 PM
cynick's Avatar
I don't know if it is more heavy duty but we got Seth's from Motion Pro. Hope that helps.
Old Jun 16, 2007 | 03:44 PM
TheStir's Avatar
Started riding ATVs in 1974!
OMR,
I have a Motion Pro that I got through RW, My 2000 flywheel came right off, but I used an impact wrench to do it. Just light taps on the impact and it pooped it right off.
Scott
Old Jun 16, 2007 | 04:03 PM
OMR's Avatar
OMR
I do heatup the hub and lighltly tap, but each time I use the puller, you can still tell that the threads on the puller are stretching. After about ten uses the threads finally let go.
There use to be other people like Marky that also sold stronger pullers, but it looks like that option is no longer available.
I am going to ask my local dealer where he got his, it looks more rugged.
OMR
Old Jun 16, 2007 | 08:30 PM
Boomer84's Avatar
Have been using same puller for 4 years , I guess thats about 150 engines,use a propane tourch for about 2 min.
Old Jun 16, 2007 | 09:59 PM
OMR's Avatar
OMR
I guess in the future I will try alittle more time heating.
Thanks
Old Jun 17, 2007 | 01:19 AM
MRDS650's Avatar
Canadian and Proud of it !!!
I stripped my puller that i got from bomb a few times. Ended up welding a nut on top of it.
I was surprised how much heat it took. After heating with a set/acc torch for about 2 minutes it popped right off.
chingchangchong
Aug 7, 2022 11:36 AM
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
raman8tor
Sep 20, 2015 07:35 AM
