no bottom end power
bought the gio 110cc a month or so ago for my daughter have had problem with the charging system.i did not realize until a friend bought one for his son how slow mine is off the start.really seems to bog until you get some speed up.my friends on the other hand can spin the tires in the gravel off the start.any suggestions would be great
thanks Scott
thanks Scott
<div class="FTQUOTE"><begin quote>Originally posted by: scottbrett
thanks Scott</end quote></div>
Almost sounds like the carb needs attention. Maybe the air/gas needle needs to be turned out to lean it a little (pilot jet) and/or the needle on the slide needs to be adjusted one notch.
You seem to have a rich condition. Maybe the air filter is dirty, or the carb is out of adjustment and/or dirty itself, or the choke is not working correctly and is still choking. The starter valve may not be closing all the way, anyway here are some possible causes.
Problem: Idling or low speed impaired
Condition Remedy
1. Slow jet obstructed - loose 1. Clean - tighten jet
2. Slow jet outlet obstructed 2. Clean outlet
3. Low speed fuel screw setting incorrect 3. Adjust screw
4. Starter valve not fully closed 4. Adjust valve
5. Float height incorrect 5. Adjust float height
Problem: Medium or high speed impaired
Condition Remedy
1. High RPM "cut out" against RPM limiter 1. Shift into higher gear - decrease RPM speed
2. Main jet obstructed 2. Clean main jet
3. Needle jet obstructed 3. Clean needle jet
4. Throttle vacuum piston not operating properly 4. Check piston operation
5. Filter obstructed 5. Clean filter
6. Float height incorrect 6. Adjust float height
7. Starter valve not fully closed 7. Adjust valve
Condition Remedy
Condition Remedy
not familar with a starter valve? the bike has done this since first start up,the air filter is still like new.
do i move the clip down to the point end of the needle or or up to lean it out .
To make it lean move it away from the pointy end. It makes the needle longer so to speak letting less gas in.
Here is a good Q&A for you to read. http://www.dfn.com/benkaren/jetfaq.html
There are some good questions and some good answers here.
Scott i just got my sons atv today and its doing the same thing. I have it so he cant go very fast but i have to give him a push to get him started. Did you every get yours running better?
Thanks
Jeff
Thanks
Jeff
