no bottom end power
Old Jun 17, 2007 | 05:32 PM
scottbrett's Avatar
Default no bottom end power
bought the gio 110cc a month or so ago for my daughter have had problem with the charging system.i did not realize until a friend bought one for his son how slow mine is off the start.really seems to bog until you get some speed up.my friends on the other hand can spin the tires in the gravel off the start.any suggestions would be great
thanks Scott
Old Jun 17, 2007 | 06:38 PM
buckaroo50's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: scottbrett
thanks Scott</end quote></div>
Almost sounds like the carb needs attention. Maybe the air/gas needle needs to be turned out to lean it a little (pilot jet) and/or the needle on the slide needs to be adjusted one notch.
Old Jun 17, 2007 | 07:29 PM
NLWarrior01's Avatar
Did you change the spark plug from the one that came with it to a good quality NGK one? Apparently that causes some grief as well.
Old Jun 17, 2007 | 11:52 PM
scottbrett's Avatar
Yup replaced the plug as soon as i got it.even on slight hills or a minor obstical i can have it near full throtle and it just bogs down wont even spin the wheels
Old Jun 17, 2007 | 11:56 PM
scottbrett's Avatar
do i move the clip down to the point end of the needle or or up to lean it out .
thanks Scott
Old Jun 17, 2007 | 11:58 PM
buckaroo50's Avatar
You seem to have a rich condition. Maybe the air filter is dirty, or the carb is out of adjustment and/or dirty itself, or the choke is not working correctly and is still choking. The starter valve may not be closing all the way, anyway here are some possible causes.
Problem: Idling or low speed impaired
Condition Remedy
1. Slow jet obstructed - loose 1. Clean - tighten jet
2. Slow jet outlet obstructed 2. Clean outlet
3. Low speed fuel screw setting incorrect 3. Adjust screw
4. Starter valve not fully closed 4. Adjust valve
5. Float height incorrect 5. Adjust float height
Problem: Medium or high speed impaired
Condition Remedy
1. High RPM "cut out" against RPM limiter 1. Shift into higher gear - decrease RPM speed
2. Main jet obstructed 2. Clean main jet
3. Needle jet obstructed 3. Clean needle jet
4. Throttle vacuum piston not operating properly 4. Check piston operation
5. Filter obstructed 5. Clean filter
6. Float height incorrect 6. Adjust float height
7. Starter valve not fully closed 7. Adjust valve
Old Jun 18, 2007 | 12:06 AM
scottbrett's Avatar
not familar with a starter valve? the bike has done this since first start up,the air filter is still like new.
Old Jun 18, 2007 | 12:07 AM
buckaroo50's Avatar
To make it lean move it away from the pointy end. It makes the needle longer so to speak letting less gas in.
Here is a good Q&A for you to read. http://www.dfn.com/benkaren/jetfaq.html
There are some good questions and some good answers here.
Old Sep 4, 2007 | 12:18 AM
jnt3000's Avatar
Scott i just got my sons atv today and its doing the same thing. I have it so he cant go very fast but i have to give him a push to get him started. Did you every get yours running better?
Thanks
Jeff
Ronk407NY
Feb 13, 2016 11:05 AM
1966F100
Aug 21, 2015 07:10 PM
Polarisman1123
Aug 13, 2015 08:13 AM
Gtsordo
Jul 22, 2015 01:27 PM
tweeder
Jul 5, 2015 01:57 PM
