400 rancher at
Old Jun 25, 2007 | 02:36 PM
brian42's Avatar
Default 400 rancher at
My bike is haveing a hard time moving in auto. Feels like the breaks are draging but they are not. Can any one help?
Old Jun 26, 2007 | 12:34 AM
Gimpster's Avatar
You burned out the centrifical clutch weights and drum
Edit:
For your info and others in case you did not know, one of the shift points in the 400AT at lower speeds can 'confuse' the tranny in auto mode. This in turn will cause the centrifical clutch shoes to constantly engauge or disengauge. Some it happens so quickly that they will excessive slip on the drum. Friction heats. It will groove the drum and warp it. The grooves and warping will make it worse ( the situation where it seems your brakes are locked )
I have replaced a number of parts also related that have been damaged from the heat. Centrifical clutch shoes, drum, return springs and a few sprag bearings when everything is just black from being fried.
In 2004 they had an updated ECU that had a different shift map in it that cured most of the problems. I have seen this happen on 2006 models though. I suggested to Honda that they come up with a stiffer return spring set to get the engagement of the centrifical clutch higher and away from this programed shift point. If they take note or not is up to them. They have engineeres that know more than me
----- Gimp -----
Old Jun 27, 2007 | 01:24 AM
HondaFinn's Avatar
Had the same problem with my 2004. Google "Rancher 400 at problems" & you will see that you are not alone. I solved it by selling the machine & buying something different. Hope things go better for you.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
