New Member with problem
Old Jun 28, 2007 | 08:32 PM
Starstruck1's Avatar
Default New Member with problem
Hi All,
I am a new member in search of some help!
My Rancher suddenly will not start - battery, cables, fuses, etc. all good. Sometimes the dash/indicator lights will come on, other times NOTHING happens. When the indicator lights DO light up, he "4x4" light on the dash blinks 4 times then stops, 4 times, then stops - continues this sequence.
I understand that this is a diagnostic indicator for one of the sensors - but not sure which one.
Last hunting season, I had a couple problems with the transmission not wanting to come out of ES mode and not shifting out of 1st gear. This happened only 2-3 times and would usually clear the problem by turning the key off then back on.
Can anyone offer insight/advice on this "diagnostic light/code" problem?
Thanks in advance,
Brenda
Old Jun 28, 2007 | 09:25 PM
coonhound130's Avatar
Mine used to do that , tured out it was a loose battery cable , felt tight to the hand , but loose enough it would nat make connection sometimes ...Just a thought
Old Jun 28, 2007 | 09:33 PM
Thank you - I'll check the cables again to be sure (clean them).
If I put slight downward pressure on the starter solenoid, the dash/indicator lights will come on but the bike still will not start - tried jumping (by-passing) the solenoid but this did not help either. Forgot to mention this in the original post.
Still just get that "4 flash sequence" on the 4x4 indicator light...
Brenda
Old Jun 28, 2007 | 11:03 PM
I will be going to the dealer tomorrow for some parts , I will ask the tech while I am there about your problem and see what he says .....Let you know either friday night or saturday morning
Old Jun 28, 2007 | 11:10 PM
Thank you, that would be absolutely GREAT! Truly a very nice offer from you. I look forward to hearing back from you.
BTW, I did contact me dealer about this earlier today - their answer was "can't help you unless you bring it in so we can look at it". Yeah, right....
I'm going to check on buying a Honda shop manual - just need to find the right place to do so!
Thanks again!
Old Jun 29, 2007 | 12:21 AM
Gimpster's Avatar
Repair your electrical problem first. Once you have good contact of the battery cables everywhere, the 4 code should go away. It is a system voltage error code.
If it does not go away after other electrical issuses are taken care of, clear the codes. It should not flash again.
----- Gimpster -----
Old Jun 29, 2007 | 01:50 AM
Thank you....I'll go over the connections tomorrow and see what happens...
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
