NEW USER!!!
Old Jun 28, 2007 | 11:48 PM
TWITCH250's Avatar
Default NEW USER!!!
Hello guys,
I have a couple questions about a quad i might be buying.,..its a 2004 Honda 250 EX...but the problem is..its blown up...I was thinking about dropping a bigger motor into it, but i dont know what io would have to do to make it fit. I was thinking about a 300EX Motor
My question about that is,,
will it fit in the frame or will it stick out the sides a lot...i know i have too do some modifications for the motor mounts...but will i be able to fit the exhaust through it???
a 300ex is chain driven am i right?? Im gunna have to buy a whole swing arm and how hard is it to install that....
wil the exhaust off the 250 fit...hes got an fmf pipe that i want to keep but idk if it will work...if you guys can give me sum info on this idea that would b great
Thanks alot
Brandon
Old Jun 29, 2007 | 01:13 AM
Gimpster's Avatar
Default NEW USER!!!
Sounds like a lot of work
Old Jun 29, 2007 | 09:39 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default NEW USER!!!
First off, the 250EX has limited suspension. That means when you hop it up, you will quickly find yourself outriding the machines abilities. I don't know of any really substantial aftermarket suspension improvements for this machine, but I wouldn't go bigger without doing that first!
Second is what you already mentioned. Shaft vs chain drive. How you going to get a chain drive engine mated up to a shaft drive rear end????
This is a beginner's quad. Most folks are going to ride it and get some experience, then graduate to a real sport quad....with real suspension. If you are looking for a project, just rebuild the stock engine, and then look for some suspension improvements........
Old Jul 1, 2007 | 08:24 PM
TWITCH250's Avatar
Default NEW USER!!!
it was either that or buying a big bore kit...but i dont know where to get one...i was thinking dennis kirk or something, but i couldnt find anything
bmxatv10
Oct 14, 2022 06:23 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
tysonbully
Sep 28, 2015 02:30 AM
Jeff Roper
Sep 21, 2015 02:11 PM
WilliamBos
Sep 6, 2015 10:53 AM
