no spark
Old Jul 2, 2007 | 03:37 PM
yfzcdb450's Avatar
Default no spark
I recently stripped my YFZ to paint the frame and after I put it back together it wouldn't start. I checked the plug for fire and it wasnt firing. Swapped plugs...still no fire. I checked all my connections and the spark plugs with an ohm meter and everything is fine. When i checked to see if I had current coming through the spark plug wires my meter barely moved. The motor will turn over so I'm lost. Can anybody help??
Old Jul 2, 2007 | 04:02 PM
mdebuck's Avatar
Default no spark
recheck your connections after you recheck double check your connections also check your grounding wires
Old Jul 11, 2007 | 01:01 AM
Vunit's Avatar
Default no spark
everything was working fine i take it when u start to disconnect everything and pull it apart right...make sure that every wire is in its proper home connetion first...its kinda sounded like a ground wire for sure...make sure where grounds are theres not a ton of paint there so there some metal so it can grap...but being how u just painted it that could be the problem...i would just check everything over again...u can never over check anything...
Old Jul 11, 2007 | 01:06 AM
mdebuck's Avatar
Default no spark
yfzcdb450, update so we know where your at
Old Jul 11, 2007 | 01:27 AM
Vunit's Avatar
Default no spark
good call bro haha
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
