no spark
no spark
I recently stripped my YFZ to paint the frame and after I put it back together it wouldn't start. I checked the plug for fire and it wasnt firing. Swapped plugs...still no fire. I checked all my connections and the spark plugs with an ohm meter and everything is fine. When i checked to see if I had current coming through the spark plug wires my meter barely moved. The motor will turn over so I'm lost. Can anybody help??
no spark
everything was working fine i take it when u start to disconnect everything and pull it apart right...make sure that every wire is in its proper home connetion first...its kinda sounded like a ground wire for sure...make sure where grounds are theres not a ton of paint there so there some metal so it can grap...but being how u just painted it that could be the problem...i would just check everything over again...u can never over check anything...
fordfaithful21
12-07-2015 05:52 PM
Cdenton
Technical and How-To Articles
09-09-2015 11:23 AM
