Trouble with 300 Rear End
Old Jul 15, 2007 | 08:16 PM
300Rider's Avatar
Default Trouble with 300 Rear End
I believe I blew out my rear bearing. When riding it "clunks". I lifted up the back end and there seems to be about 1/4'" of slop on the right side.
How do I take apart the rear axle?
Old Jul 15, 2007 | 11:15 PM
HondaMechanic's Avatar
Sounds like the brake panel bearing , they need replacement quite often .. It's possible the rear end bearings are bad also , you'll know when you get the axle out ..
Old Jul 15, 2007 | 11:18 PM
What year TRX300 is your bike & what's your email address and I will email you the rearend section from the Honda TRX300 PDF shop manual ...
Old Jul 15, 2007 | 11:22 PM
coonhound130's Avatar
Mine done the same thing , turned out the ear for the brake shoes was broke off and getting in a bind .
Old Jul 15, 2007 | 11:35 PM
We've fixed several that broke .. drilled the center right thru and put a bolt & nut to hold it ..
Old Jul 19, 2007 | 10:14 AM
300Rider's Avatar
Purchased a repair manual from dealer ship. Thanks for offer of sending me sheets.
Old Jul 19, 2007 | 10:22 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It is best to just consider bearings to be disposable items that need to be replaced now and then. If the axle is wobbling, don't ride it like that because you can damage the carrier and then you are in for big $$$.
There are some tricks like putting the bearings in the freezer so they shrink before installation. Not sure if the manual goes into stuff like that?
Old Jul 23, 2007 | 01:05 PM
300Rider's Avatar
Reconranger, where were you 2 weeks ago? Finally go it apart and the bearing had completely disentegrated. As soon as we started to pull the axle out the ball bearings poured out. The carrier is damanged. If only the bearing had been bad it would have been $75 in parts. Looks like even using discount part suppliers it will be closer to $350.
The only good news is the carrier as a service part comes with the bearings already installed.
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
Sep 9, 2015 10:56 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
toonces
Sep 5, 2015 01:14 PM
