Neutral start switch on Honda Rancher
Old Jul 24, 2007 | 10:12 AM
Yankee Boy's Avatar
Default Neutral start switch on Honda Rancher
We have a 350 Honda Rancher with an electronic trans mission.
More than half the time when you want to start it, and the transmission is in neutral it just clicks and won't turn over. Sometimes it turns over weakly.
The lights are bright and it acts the same with or without a charger to supplement the battery, so I don't think the battery is the problem. It starts instantly when you pull the cord.
Is their a neutral start switch on this machine?
Is there something that can prevent it from closing? (I have noticed if I put the thing in gear and rock it back and forth against first gear, the thing will start right up)
Help!
Old Jul 24, 2007 | 10:53 AM
HondaReconRider's Avatar
i have got a recon es (electric shift) and i have had this same problem. i had to replace the angle scensor and a new battery... but first i would just get a new angle scensor..
Old Aug 6, 2007 | 11:50 AM
usry's Avatar
My rancher did this needed starter rebuilt
Old Aug 6, 2007 | 12:55 PM
quicksilver's Avatar
yes, it sounds like the electric shift system is working properly- its the stater system that seems to have the problem... When you try to start it, you hear the starter relay under the seat clicking, that means that all the neutral saftey junk is working properly. the power is either not getting from the relay to the starter, or the starter has power but is worn out and faulty. you could also have a dirty cable connection beween the relay and the starter, good way to check this is to put one lead of a volt meter on the battery positive terminal and the other terminal of the meter where the cable connects to the starter, put it on volts mode and attempt to crank the engine over- disconnec the coil wire so it doesnt start, and see if you have any voltage. .5 volt is probably ok, 1 volt or more means you have high-resistance in the cable or at the connections, this is what we call a "voltage drop" test in automotive diagnosis, but works the same for any electrical circuit that is flowing current.
i would put my bet on a worn out starter though.
Old Aug 6, 2007 | 07:19 PM
mykool61679's Avatar
sounds like the battery!!
Old Aug 6, 2007 | 10:52 PM
angler's Avatar
When you hit the starter button, does it click once or do it keep on clicking like a dead battery? If it just clicks once, try hitting the starter with your hand with the starter button pushed and see if it starts.
neilbedwell
Nov 10, 2018 11:02 AM
ROWALKER
Jun 15, 2015 05:38 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
aby11
May 7, 2000 07:58 PM
Rancheres4X4
May 5, 2000 02:09 AM
