Rappy 660 no spark?!?!
Old Jul 26, 2007 | 09:42 PM
b4evercountry's Avatar
Default Rappy 660 no spark?!?!
Just as title says... as i was riding one day... just putting around the house 1-3 gear easy throttle, just died.... I now have no spark. Got a new plug, Battery is good, and its gettin fuel and all... Any ideas?
Old Jul 26, 2007 | 10:28 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
chec kthe coil
Old Jul 29, 2007 | 09:17 PM
checked the ignition coil.... remember, im new to the ATV thing. But i got about 28v running into the ignition coil. Yet nothing coming out of the spark plug boot when i crank it over. This mean the coil is shot i take it?
Old Jul 29, 2007 | 09:40 PM
Kerbmonster's Avatar
the only way u can check voltage on the coil is if u have a peak voltage adaptor for your multimeter, i would check resistance and insulation breakdown, insulation breakdown u should get OL on ur meter. the breakdown test is done by taking one lead to the primary side of the coil and to ground, if u get resistance, then the coil's bad, u can check the primary resistance by going from the primary side of the coil with a test lead, to the other side of the coil through the plug cap, you should get a reading with about 9 - 13 K ohms, if u get OL, then the coil is bad.
Old Jul 29, 2007 | 11:51 PM
i get no resistance on the first one and about 8.2 on the second one.... is it ok?
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
