Panther 110 ATV starter problems
I have a panther 110 ATV that I purched from an independent dealer in my area. It is manufacture by Buyang and inported by Jinsli. It would not start yesterday, starter made a high spin sound. I took the starter loose but could not get it to release from the motor because it is driving a chain that is attached to a ..clutch ***? I took the silver tube off and pulled out the wire ***. It looked fine and so did the brushes. I put the starter back on and reinstalled the brushes and silver tube. I checked the battery and it only showed 8.5 volts. I charged the battery overnight on a Auto trickle charger set for the small size battery and it charged to 12.5 volts. I put starter back in, and now it will just make a loud click sound. When I removed the starter housing, could I have got the chain off or bound that goes down in the engine. If so can, I remove that LH cover easily to put back on or adjust with starter. I believe there is some sort of plug in the center which looks like can be removed. Could it still be the battery, solienoid switch? Can I try to jump start with my lawnmower battery without damaging the stator? Could starter be bad? It gets hot when it makes the click sound.
KimSJoh
14
Jul 18, 2015 07:20 PM
