Panther 110 ATV starter problems
Old Jul 27, 2007 | 02:34 PM
jrachal's Avatar
Default Panther 110 ATV starter problems
I have a panther 110 ATV that I purched from an independent dealer in my area. It is manufacture by Buyang and inported by Jinsli. It would not start yesterday, starter made a high spin sound. I took the starter loose but could not get it to release from the motor because it is driving a chain that is attached to a ..clutch ***? I took the silver tube off and pulled out the wire ***. It looked fine and so did the brushes. I put the starter back on and reinstalled the brushes and silver tube. I checked the battery and it only showed 8.5 volts. I charged the battery overnight on a Auto trickle charger set for the small size battery and it charged to 12.5 volts. I put starter back in, and now it will just make a loud click sound. When I removed the starter housing, could I have got the chain off or bound that goes down in the engine. If so can, I remove that LH cover easily to put back on or adjust with starter. I believe there is some sort of plug in the center which looks like can be removed. Could it still be the battery, solienoid switch? Can I try to jump start with my lawnmower battery without damaging the stator? Could starter be bad? It gets hot when it makes the click sound.
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
