Weird 240 blaster vs 200 blaster
Old Aug 10, 2007 | 12:02 AM
mdebuck's Avatar
Default Weird 240 blaster vs 200 blaster
heres the story my dad and i recently purchased a 1999 blaster with g force reeds,vitos 240,fmf expansion chamber,fmf power core 2,12 tooth sprocket, hot rod crank,holeshot tires,aftermarket clutch plates,foam air filter, and thats all i can remember ok now my 2003 blaster has power core 2 silencer fmf header pipe fmf carb jets,razr tires,and a k & n air filter.... me and jhim decided to drag race on the pavement so he said go and we both took off and we were dead even the whole way he was on the 240 and i was on the 200 he is also about 40-50 pounds heavier than me so what does this sound like to you does it sound right or what ...we both have the same level of experience and i almost think its got to do with the weight..let me know what u guys think
Old Aug 10, 2007 | 01:22 AM
Blaster96's Avatar
I would suspect the 99 is not tuned properly. It may need jetting or a larger carb to feed the 240 kit. I would not think 50lbs would slow the 240 down that much, however the Blaster engine is not what you can call a torque machine... Why don't you switch rides and race agian?
Old Aug 10, 2007 | 11:54 PM
mdebuck's Avatar
we will monday when we go to st joe what size carb do u think would work
Ahtatu
Sep 28, 2015 12:14 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
Aug 6, 2015 11:49 AM
