kazuma 90 problem
Old Aug 16, 2007 | 08:46 PM
racer99b's Avatar
Default kazuma 90 problem
I have a kazuma mini falcon 90 that I can't get to start. MY daughter was riding it and went through some water and drowned it out. It started after it sat for a minute we then shut it off after that and it has not run since. we changed the oil the gas the plug. It is getting fuel to the carb it has spark but won't start. It has compression when you put your finger over the hole and turn it over. Any help would be appreciated. Could it have jumped a tooth on the cam???? any suggestions would be great
Old Aug 16, 2007 | 08:54 PM
billl2099's Avatar
clean the air filter and make sure it dry
Old Aug 16, 2007 | 10:07 PM
racer99b's Avatar
I did that and tried it nothing I even took it off when it was in the shop.
Old Aug 16, 2007 | 11:43 PM
89stp's Avatar
Any way it could have gotten water in the gas? Just an idea to check.
Old Aug 17, 2007 | 12:06 PM
oneOone's Avatar
on my mini talon, when it first went through water it did some weird stuff (hard starts, bog down, and die) after it took it apart and checked all electrical i found water in a few connections, applied deielectric grease and taped all connections. it can now run threw puddles with out issue.
so I guess what i'm saying is check your electrical just to rule it out... these bikes seem to have sensitive electrical systems.
hope this helps
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
