2006 450 Sportsman Problem, help!!!
Old Aug 21, 2007 | 01:52 AM
bhunter50's Avatar
Default 2006 450 Sportsman Problem, help!!!
I am getting a knocking noise coming from the rear end of my quad. It intensifies when i am turning and going in reverse, but it will make the noise at any given time the quad is moving, I believe that it has something to do with the rear drive arms because i noticed upon inspection that the two boots that connect them were torn. What could be my problem????
Old Aug 21, 2007 | 07:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
well your not going to want to here this, but you have 2 cv joints gone. when the boot gets ripped it allows dirt,mud,water to get inside the joint and eats them right up. evently if you keep driving it that way it might lock the wheels up. time to replace them.
Old Aug 21, 2007 | 12:17 PM
bhunter50's Avatar
how much do the parts for this repair cost and what would I need?? i might try to have a friend do it for me, i know the dealer is going to rape me. how hard will it be to fix and how long would you expect it to take??
Old Aug 21, 2007 | 04:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sent you a pm.
Old Aug 21, 2007 | 07:55 PM
bhunter50's Avatar
anyone else have anything else to add??? any help is appreciated!!
Old Aug 21, 2007 | 09:30 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you want, let me know and ill show you step by step pictures to do the removal.
Old Aug 21, 2007 | 11:35 PM
bhunter50's Avatar
sounds like it would help a lot, sent you a pm stendori
Old Aug 22, 2007 | 07:54 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: bhunter50
sounds like it would help a lot, sent you a pm stendori</end quote></div>
lol. i sent you a book this time dont loose it too much typing to waste.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 22, 2007 | 07:54 PM
bhunter50's Avatar
thanks, i think i could do it myself if i knew exactly which parts i need to order. let me get this straight the CV end is the end that goes to the demand drive and the other end goes to the wheel right??? I need the CV end (end that connects to the demand drive center opposite the end that connects to the wheel) because it is the end with the real bad torn boot right???? so do i just order it and replace it only or does the whole shaft with both sides have to be ordered?? I guess basically it doesnt sound too bad, just need to know exactly what to order. I think I will replace one side and then check and see if the other is needing it too, i can't tell if the other one is knocking or not. i know this is a lot but doing this myself would save a lot of money. aslo, could you explain the part that is NOT so easy and you would suggest taking it to the dealer and why you would do so???
Thanks a ton!!
Ltz250goon
Sport Quads
Dec 3, 2015 07:51 PM
toonces
Jun 30, 2015 11:19 AM
BillinIll
Jun 25, 2015 02:44 AM
BillinIll
Jun 19, 2015 01:39 PM
Joe Paul
May 27, 2015 09:04 AM
