05 700 sportsman dash/4wd out
I have an 05 700 sportsman with less than 400 miles that has never been sunk. The dash/speedometer and 4wd dont work. I have checked all 3 fuse blocks and all connections. Full battery power and runs and starts fine. All lights work. Was told it could be the module (finned aluminum block ahead of steering column). Any ideas? what could I check or test?
the newer bikes speedo run the awd, so if the speedo breaks you wil looose the awd most of the time. i do know the modual does controll alot of things but not sure on the speedo part.
fixing the dash is the first step--- it is wired into everything, somehow. I rolled my machine a destroyed the pod. The machine wouldn't start until i unplugged the speedo inside the pod (carb model). Try a dash first-- is it under warranty?
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
cdstang
Aug 31, 2015 07:52 AM
