Oil Tank Leak 02 Sportsman
Old Sep 2, 2007 | 09:56 AM
JKW's Avatar
JKW
Default Oil Tank Leak 02 Sportsman
Hello everyone! I hope you all had a good summer. Has enyone had problems with there tanks leaking at the drain plug? The plastic washer/gasket was in good shape, but put a new one in anyway. I suspected at that point it was leaking around the out side of the thread insert. Its a minute leak. I can belive the price they want for parts ! $104.99 for a little plastic tank!! Holly shnikys!! Probably don't get a kiss either!
I did a quick search and didn't see any other similar problems. If this isn't a common problem, I'll look for a used one.
Have a nice Labor Day weekend!
2002 Sportsman 500HO
Old Sep 2, 2007 | 11:24 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i read somewhere where someone esle had a leaking issue also. where this is only plastic i bet it wouldnt take much to crack it by overtightening orstripping threads out. if its leakingby the washer maybe try some teflone tape for pipes on the threads. just an thought.
Old Sep 2, 2007 | 11:41 AM
03scrambler500's Avatar
i had the same problem and i fixed it by making sure the oil plug and washer was oil free with some brake cleaner then i put RTV on each side of the washer and thats what i do every time i change my oil from now on and haven't had any trouble i hop this helps you.
Old Sep 4, 2007 | 07:19 PM
JKW's Avatar
JKW
Thanks for the input guys. I slowed the leak to just a weep with a larger diameter plastic washer. Hardwhare store for .30 cents, Polaris OE washer $2.50, no kiss! I'll try one of your sugestions next oil change, or if it starts dripping the way it was. Thanks again.
Jmuddin284
Jan 19, 2026 07:16 AM
SDR-II
Sep 29, 2015 01:06 AM
Sandman2.0
Jul 21, 2015 09:03 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
Shifts
Jul 3, 2015 07:59 AM
