500 scrambler backfire
Old Sep 4, 2007 | 03:49 PM
auto2tech1999's Avatar
Default 500 scrambler backfire
i still get a backfire after full throttle.its all stock.someone says to replace the 40 to a 42.5 does anyone know if this will help
Old Sep 4, 2007 | 05:38 PM
ftwflh's Avatar
Have you cleaned or changed the air filter?
Old Sep 4, 2007 | 05:43 PM
yes clead carb to
Old Sep 4, 2007 | 06:05 PM
ftwflh's Avatar
Have you checked the ETC switch?There is a way to bypass it but I am not sure how.
Old Sep 4, 2007 | 06:11 PM
by passthe etc is easy just pull the cover off and put a peace of tape between the two points of contact. but yes its fine
Old Sep 4, 2007 | 06:24 PM
ftwflh's Avatar
Try disconnecting the rev limiter.Unplug the black wire.This thing can cause all sorts of problems.
Old Sep 4, 2007 | 07:44 PM
sled05's Avatar
auto2tech
My sons 04 scrambler backfired on deacceleration. The main jet was partially clogged.
Cleaned it and problem solved
Old Sep 4, 2007 | 09:36 PM
97xplorer's Avatar
kind of off subject. but what does back fire mean?
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
