'07 SP800 Blink Code 25 ??
Old Sep 9, 2007 | 02:42 PM
Rcher's Avatar
Default '07 SP800 Blink Code 25 ??
What is code 25? Its not in the owners manual. Anyone know?
As far as I know, the check engine light didn't come on. The only reason I checked was to make sure the diagnostic center was working and this code was in there.
Help please?
Old Sep 9, 2007 | 11:21 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i couldnt find that number in the service manual. did it come up saying wait on the speedo b4 it gave you the code?
Old Sep 10, 2007 | 10:01 AM
Rcher's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
did it come up saying wait on the speedo b4 it gave you the code?</end quote></div>
Well sorta. After cycling the key 3 times it immediately starts flashing the number "2", then the "WAIT" shows and continues flashing the "5". Then it displays the actual number "25". The word "WAIT" quits. Then flashes out the end code of "61" and then displays the word "END".
Maybe its not really a fault code since the word "WAIT" is still shown during the blinking of "25". I am going to try and call Polaris today.
Old Sep 10, 2007 | 10:27 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Let us know what you find out...........Thanks............Caper...........
Old Sep 10, 2007 | 10:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yea that sounds screwed up and not like a normal code. let us know for sure.
<div class="FTQUOTE"><begin quote>Originally posted by: Rcher
Maybe its not really a fault code since the word "WAIT" is still shown during the blinking of "25". I am going to try and call Polaris today.</end quote></div>
Old Sep 11, 2007 | 10:43 AM
Ramoel's Avatar
Code 25 is on page 4.19 of the service manual in a special chart for fuel injection. The code means Transmission input-Invalid gear. I would assume it's the input from the switch on the tranny that shows what gear you are in on the speedometer display. It is also supposed to illuminate the check engine light if it's a real problem. My new 800 also had the 25 code after I unhooked the battery to charge it and then reconnected it. You can reset the code by disconnecting the battery for a couple of minutes. I reset mine and it never came back. The shift switch was also functioning fine on mine since the display always showed the correct gear.
Old Sep 11, 2007 | 05:40 PM
Rcher's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Ramoel
Code 25 is on page 4.19 of the service manual in a special chart for fuel injection. The code means Transmission input-Invalid gear. I would assume it's the input from the switch on the tranny that shows what gear you are in on the speedometer display. It is also supposed to illuminate the check engine light if it's a real problem. You can reset the code by disconnecting the battery for a couple of minutes.</end quote></div>
Excellent information and thanks! After disconnecting the battery for about 5 minutes then re-connecting it, the code 25 had cleared. My dealers service manager is out for a couple of days so couldnt get an answer from them either. Polaris was of no help at all. I will continue to investigate the reasons why this happened but atleast now I know its not anything too serious unless the check engine light comes on.
Thanks Ramoel, you have been of great help.
Old Sep 11, 2007 | 07:17 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i must have a differnt book that im looking at because i dont see that. i see differnt trouble shooting on that page but this is also for an 05' good info to have thanks.
speedbuff
13
Nov 11, 2020 10:16 AM
Sw00p
Sep 24, 2015 02:50 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
