trx 300 needs to be choked
Old Sep 15, 2007 | 07:29 PM
poophead's Avatar
Default trx 300 needs to be choked
it starts and runs but needs to be choked to give any throttle.
Old Sep 15, 2007 | 07:56 PM
HONDA CRUSHER 93's Avatar
try adjusting your idle.if you don't know how turn the screw on the carb. that has a spring around it.
Old Sep 15, 2007 | 08:06 PM
poophead's Avatar
sorry ,i miss informed you on the 300 ex and the fact is that it will stay running but to take off and get any speed out of it at all i need to choke it .
Old Sep 15, 2007 | 08:50 PM
i thought that you were talking about a fourtrax(utility)
Old Sep 15, 2007 | 10:54 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Check for an air leak somewhere....the boot, air filter, etc. The leak is giving it to much air, but when you choke it down it makes up for the leak (?????).
Old Sep 16, 2007 | 12:23 AM
poophead's Avatar
i took the carb off to find crapola around the jets i cleaned all the jets and drained the gas tank and now it runs better but it acts like it wants to go slow until i choke it for 3-5 seconds then it'll take off . do i need to clean it again or is the float messed up or do i need to put a kit in the carb ? i give .
Old Sep 16, 2007 | 10:45 AM
Red Rider
Didn't say of you checked for an air intake leak or not? This would be BEFORE the carburator, like in the rubber boot between the air filter and the carb (or even a messed up air filter).
Take off the air filter, and put your hand over the hole. Crank the engine a couple of times and it should make a vacume. The vacume should hold for a while. If it doesn't hold, you have a crack in your boot or something.....
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
