90cc predator runs rough
Old Sep 19, 2007 | 07:55 PM
Stiner1's Avatar
Default 90cc predator runs rough
I`m working on an 02 90cc Predator for a friend. I`ve soaked and cleaned the carb, replaced the plug, and cleaned the air filter. I`ve also adjusted the carb, but this thing runs the best when the choke is 1/2 way on. It boggs down when you turn the choke completely off, any suggestions?
Old Sep 20, 2007 | 12:49 PM
sheepdogMSP8117's Avatar
Will it idle on it's own? If it runs best with the choke on, then it is starving for fuel. Make sure there are no air leaks between:
1. the airbox and intake boot.
2. the intake boot and carburetor.
3. the carburetor and manifold.
4. the manifold and cylinder head.
Also make sure the intake boot is not cracked or dry rotted to where air is getting in through a small hole or crack.
If no air leaks, then the carb might need further cleaning in the main jet or needle jet.
Old Sep 20, 2007 | 08:04 PM
itch's Avatar
did you clean the pilot jet?
Old Sep 21, 2007 | 01:51 PM
Stiner1's Avatar
Yes, I tore it down and soaked it in 2 gallons of crb clean.
Old Sep 21, 2007 | 01:54 PM
Stiner1's Avatar
I`ve sprayed some carb cleaner all around it to see if it died, it didn`t. I don`t think there is an air leak. By the way, yes it idles fine, just sputters out when throttling it.
SOLOLUCKY
Oct 4, 2024 09:09 PM
cbcole02
Sep 7, 2015 06:16 AM
wannabe32
Jul 7, 2015 11:30 AM
Falcon150
May 25, 2015 05:36 AM
hot_shoe_cv
Oct 13, 1999 02:16 PM
