No neutral? No neutral light?
Old Sep 22, 2007 | 05:45 PM
W4rri0r2000's Avatar
Default No neutral? No neutral light?
I don't know guys but when I flip the key switch the neutral light doesn't come on! The only way I can start it is with the clutch pulled in. My quad like thinks it's in 1st gear or something. I kept kicking it back up to neutral but no light! If I keep turning it on like that is it bad? Also is I expensive to fix? I don't think anything is actually broken I think something might have slipped, I just need to know where to look. What happened was when I drove it into my shed I hit it along the side of the opening of the door and it skid it then just shut off! I am like 90% sure something just slipped or fell off, I just don't know where to look for it.
Old Sep 22, 2007 | 11:47 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
the wire under the shift level came off, or is loose
Old Sep 23, 2007 | 01:30 AM
Well it wasn't off but it was a little dirty and little loose. THe thing is though when I put it into "neutral" I still can't roll it as if it is still in gear. So maybe it is in gear and I'm simply not putting it into neutral? A buddy of mine said to pull it back and forth and to keep kicking the shifter down a speed until I'm to Neutral.
Old Sep 23, 2007 | 01:37 PM
Speedy2222's Avatar
get on level ground, put it all the way down.. then bring it up VERY slowly until you feel it softly click.. it's tricky... have to have a knack for it of you'll have trouble... all the way down is 1st gear... pushing it forward and back will help the transmission see a zero load and help it shift VERY easily(by hand) if u have a problem shifting you may want to get a yz250 shifter( i beleive it is)
Old Sep 24, 2007 | 01:09 AM
HONDA CRUSHER 93's Avatar
i didn't even know that they had neutral lights, i've rode three(89,95,95) and none of them have had a neutral light
Old Sep 24, 2007 | 07:12 PM
Yeah mine is a pretty fresh one, year 2000. I figured out the problem... it was so stupid.
Old Sep 24, 2007 | 07:18 PM
Speedy2222's Avatar
what was it?
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
Tim Shoe
Sep 7, 2015 12:15 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Pahuntman
Sep 5, 2015 11:07 AM
