97 Sportsman 500 transmission
Old Oct 1, 2007 | 01:51 PM
slonez's Avatar
Default 97 Sportsman 500 transmission
anyone have decent advice or instructions on adjusting the transmisison on a 97 sportsman 500? When putting my machine in either forward gear, you're able to ride normally for about a minute - then the reverse light comes on and the spitting and sputtering starts (like you're actually in reverse) - pressing the override button allows the machine to take off like a bullet again. I've noticed that while stopped, and according to the shifter the bike is in neutral, the reverse light is still lit, but if you push the shifter forward just a bit, the transmission sounds like it's engaging, and for a brief moment the neutral light comes on. I've checked the rev limiter and for broken wires, and everything seems o.k., but the shifter does seem like it's gotten "shorter". I'm wondering if the transmission isn't fully engaging and/or some type of switch is faulty. Any advice is more than greatly appreciated!
Old Oct 2, 2007 | 12:26 AM
94harley's Avatar
I would bet money your gear selector switch is no good. They made them out of plastic for a while and they would do exactly what your talking about. Check it out.
Old Oct 2, 2007 | 09:31 AM
NBsportsman's Avatar
Yep gear selector switch, only one on the transmission with wires. Not sure if that year has one or two......
Old Oct 2, 2007 | 09:42 AM
slonez's Avatar
that sounds like good information. Would either of you know how bad that is ito replace? where would I start?
Old Oct 2, 2007 | 10:34 AM
94harley's Avatar
That switch is in the gear selector itself, not on the trans. Remove the gear linkages, remove the gear selector box and wiring, tear it apart and replace the switch. It's not too bad to do. It needs lined up in a hole when you go back together so you do need to be carefull. Also there are two pretty good springs to contend with. It has oil in it and is sealed with sealer. Just pay attention to how it comes apart and it should be ok.
Your part number is 3233209
Old Oct 15, 2007 | 02:52 PM
slonez's Avatar
I would like to thank everyone for the great outpouring of help! I pulled everything apart and replaced the switch, and the machine runs like a top. I'd be lost without the great help of this site! Thanks once again!
Jmuddin284
Jan 19, 2026 07:16 AM
greg74
Sep 10, 2019 03:03 PM
cornermike
Aug 10, 2016 06:47 AM
oldschool64
Aug 12, 2015 07:13 AM
bikedad3
Jul 2, 2015 02:15 AM
