Tecate 4
Old Jan 6, 2001 | 10:06 PM
letitsnow's Avatar
Hey all of you T4 owners, is the Tecate clutch basket the same as an '88-89 KX250? Any other year KX?
Old Jan 8, 2001 | 06:58 PM
brianc's Avatar
To my knowledge, the clutch basket is unique to the Tecate lineup. It is supposed to be the same for 3 & 4-wheelers, but the KX clutch basket is different. I just tried to verify all this on www.buykawasaki.com , but I can't get into the parts catalogs right at the moment. If you haven't already heard of this website, check it out! I did get on recently, and in the parts catalog it has exploded parts diagrams for Tecate's. Makes it really easy if you've taken yours apart and can't quite remember how it went back together! What's the problem with your clutch basket? Just plain worn out? Or did the needle bearing fail and wipe out the bore? I had that problem on my '87, and I solved it by just eliminating the needle bearing and installing a bronze bushing. That is what most manufacurers (Kawi being the exception) do for a clutch hub bearing anyway, so it's a perfectly acceptable repair.
Old Jan 8, 2001 | 09:10 PM
letitsnow's Avatar
brianc...Thanks for the info. My clutch basket is ok. I was just curious,wanted to see if Hinson made a basket for it(in case I ever need one). Did you have a machine shop make the brass bushing for you? I've been to the Kawi sight, it is helpful.
Old Jan 9, 2001 | 10:31 AM
brianc's Avatar
No, I did the work myself, as I am a machinist. Pretty handy occupation when it comes to riding quads and bikes, 4-wheeling, and playing with streetrods.
TecateRider
May 10, 2001 09:52 PM
Aaron10
Mar 29, 2001 06:06 PM
CALDS650
Mar 13, 2001 10:20 PM
scottbl99
Feb 10, 2001 12:06 AM
SandDraggin
13
Apr 20, 2000 02:07 PM
