nead info on 1986 200sx
Old Oct 25, 2007 | 07:02 PM
jbarr69's Avatar
Default nead info on 1986 200sx
i have a200sx will not shift stuck in 5th geare
Old Oct 26, 2007 | 01:34 AM
KNOWSALOT's Avatar
The Facility
Did you have the left side cover off to repair due to a thrown chain? Its a big problem on this machine when not adjusted correctly is why I ask and alot of people who remove the cover loose the thrust washer on the shaft when putting the cover back on and causes the shift linkage to be binded up.
If this doesnt apply, there are many things it could be. You can inspect the shift shaft, detent arm, detent spring, and shift drum from the right and left case covers but the tranny itself and the shift forks can only be accessed from splitting the engine cases.
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
