95-05 wolvy susp.
Old Oct 25, 2007 | 09:20 PM
wolverine68's Avatar
Default 95-05 wolvy susp.
I did a little searching, but came up empty handed. I've heard Raptor front shocks will bolt on the 95-05 Wolvy. Has anyone done this? How did they perform? Is there any direct bolt on(take offs) that will work on the rear? How do they work?
Old Oct 26, 2007 | 11:36 PM
Bump to the top I go!!!
Old Oct 28, 2007 | 12:45 PM
skramblr's Avatar
I can't answer for sure, but...
Raptor comes in 5 flavors - 700R, 660R, 250, 250 and 80. I have a set of shocks laying around from my 660R. I looked and they really don't look like they would work. The Raptor 660R rear shocks are a few inches shorter than the Wolfy's - and the wolfy is heavier. The diameter of the spring on the shock is also much larger and it looks like it probably doesn't give enough clearance to the swing arm. The Raptor's front shocks are also much longer. The geometries between the Raptor and Wolfy are completely different.
I want new shocks for my Wolfy, but I wouldn't even attempt to put the Raptor shocks on it (and I have them laying around).
Old Oct 28, 2007 | 08:57 PM
I think that the raptor fronts will work. A buddy has yzf450 fronts on his already. I didn't think the rear would work off of either of these machines as they have a rising rate rear linkage set up. I guess I'm out of luck for the rear.
Old Oct 29, 2007 | 08:58 PM
No more input from anyone?
Old Nov 2, 2007 | 02:55 PM
Last try...bump.
shastadog
Nov 19, 2003 06:49 PM
96Wolvy
Oct 15, 2003 11:30 PM
pairof98s
Dec 12, 2002 09:03 PM
ASJR85
Aug 27, 2002 05:53 PM
dmh
Dec 13, 2000 08:39 PM
