Warrior Troubles, Some Input Please, ANYONE
Old Oct 29, 2007 | 01:33 PM
certifiedwarrior's Avatar
Default Warrior Troubles, Some Input Please, ANYONE
i just picked up a 1998 warrior 350 and it only has 50 hours or so and only been sank once. i know cuz i did it when my buddy got it new back in the day. so i know the history. here is the inlaying problem. stock mikuni carb and parts. only main jet has been replaced (it was stuck in the jet port from sitting so long). bike starts great, runs like hell. i am gettin a cough and spit and bog out when given any amount of throttle. at first after the jet replacement, it would rev up as much as you want, but once in motion it bogged down and stalled. if someone has some sort of input, or tech advice, i am tech savvy, certified in motorcycles, and familiar with mikuni carbs, but i am at a brain fart and dont know which way to turn. thanks.
Old Oct 29, 2007 | 02:25 PM
STRAIGHTUPDAHILL's Avatar
try reading any of the 100s of other threads about this problem
Old Oct 29, 2007 | 03:37 PM
you know, if there was an actual thread about a carb bogging problem, i would smartass. however, there is not one, u know of one, send me the link. thanks for the help, i meant useful input, not useless.
Old Oct 29, 2007 | 06:46 PM
Raptor450's Avatar
Have you cleaned the whole carb? There are more jets and passages that need cleaning other than the main. Sounds like the low speed circuit is stopped up, which has a pilot jet that is probably clogged. You may want to soak the carb in cleaner for a few hours to loosen up all the gunk, then scrub the bowl if you haven't already and blow out all the jets.
Joe454
Nov 20, 2020 01:19 PM
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
Bernhard
Sep 25, 2015 12:45 PM
