idle speed
Old Oct 30, 2007 | 08:23 PM
kysuperstar99's Avatar
Default idle speed
I have a 2004 Polaris 330 magnum 4x4. I had it worked on and got it back but the idle was set up way too high. Does anyone know the idle speed for this machine. I got it set on 1500 right now.
Old Oct 30, 2007 | 08:34 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default idle speed
Well the idle speed for my 2006 Sp 450 is listed in the factory service manual at 1100+/-200 RPM
That may help you a bit!!.......Caper...........
Old Oct 30, 2007 | 09:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default idle speed
yea i think caper would pretty close since you arent to far from engauging the clutch i would think. it might be in your owners manual.
Old Oct 30, 2007 | 10:19 PM
Default idle speed
I checked in the owners manual and couldnt find it. I got it at 1480-1500 right now. It seems to be a little too high. I just had oil leak fixed for the second time. Also had a fuel leak fixed which was a recall item for what they said. When I got it back it was running like a jet engine(just an expression).
Old Oct 30, 2007 | 10:30 PM
Default idle speed
It must be ready to drive away by it's self!!!.......Just like Stendori said.........At what RPM does it start moving?........Caper......
Old Oct 30, 2007 | 10:38 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default idle speed
yea i checked and couldnt find it in the o. manual either. just turn it down a little your self by going counterclock wise a little. i think caper it would like yours around 1700 +- rpms.
Old Oct 30, 2007 | 10:49 PM
Default idle speed
Caper mentioned it being 1100 +/- 200. But if I set it up to where it starts moving it will be way above this. Its at 1480-1500 right now.
Old Oct 31, 2007 | 07:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default idle speed
you would actually be bringing it down to 1,100 rpms instead of running @ 1,500. jujst turn it down w/ the idle screw and try it.
Old Oct 31, 2007 | 09:36 AM
Default idle speed
You don't want it set where it will start to move on you!!!!........If you get off the quad it may take off on it's own!!....LOL......LOl.......1200 RPM's should be fine!!!........Caper.......
Old Deer Hunter
Sep 2, 2015 01:39 AM
dwhipper61
Aug 27, 2015 11:01 AM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
