tire update
Old Nov 3, 2007 | 10:33 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default tire update
tire which i tried to plug and it leaked like there was no plug in it. took it off the rim to find a 5/8" rip on the inside wall where i hit a damn railroad spike. so i had a friend of mine put one of those big patches w/ a stem on that you core out the tire and pull it thru from the insed out and it seems to worked well. didnt see him do it but looks like a great job. we'll see if it last thru the wintert and holds air.
Old Nov 3, 2007 | 01:27 PM
SCRAMMYTODD's Avatar
Default tire update
Those patches that install from the inside that have the stem on them work great. I had a buddies tire that had 2 holes close together, and I drilled a hole in between them and put the patch in. It covered both holes and is still going to this day. That was about a year and a half ago so you should be safe.
Old Nov 3, 2007 | 01:44 PM
ctateusa1's Avatar
Default tire update
another thing you can do is to add the green slime, I sealed up 2 tires that were so old they were cracking and leaking around the bead, It sealed them up within 2 miles and they havent leaked a pound of air since last year.
Old Nov 3, 2007 | 03:46 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default tire update
yea i've used slime alot and swear by it my self. the only bad thing about slime is what a MESS when you take the tire off.[img]i/expressions/face-icon-small-frown.gif[/img]
Old Nov 4, 2007 | 11:33 AM
sheepdogMSP8117's Avatar
Default tire update
So slime WILL seal a minor bead leak on and ATV tire? My buddy has a nagging bead leak that will flatten the tire in about 4 days of sitting.
Old Nov 4, 2007 | 12:48 PM
Bill35's Avatar
Default tire update
Yes slime on small leaks is the sh_t...Ive used fix a flat and never again
Old Nov 4, 2007 | 04:15 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default tire update
well another update w/ that f#$*%ing tire of mine. yep you guessed it went to take out the wheeler and its flat(yea i know only on the bottom) and the good plug is leaking. guess next spring its slime time. just a note that the orignal slime(brand name) works way better then the walmart(or other) brands by far. and bill is right in my case when ive used the good stuff it never leaked again.
Old Nov 4, 2007 | 05:21 PM
Default tire update
Well if it's only flat on the bottom, theres still 75% thats good. I say happy trails [img]i/expressions/face-icon-small-smile.gif[/img]
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
black_thunder
Sep 20, 2015 10:21 PM
highwayman
Sep 19, 2015 12:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
