96 sp 500 vacum problem
Old Nov 18, 2007 | 01:47 PM
sportsmanryder's Avatar
Default 96 sp 500 vacum problem
Hey guys I have a 1996 500 sp, when the motor is running in neutrel and I hold the gas half throdle the motor bogs, The slide in the carb is not opening, so I put my finger in the airbox and push the slide up and then the revs out how it should. for some reason the vacum from the motor is not pulling the slide in the carb up, Anyone have a problem like this, Bad cam or valve Please help. thanks
Old Nov 20, 2007 | 12:20 AM
Any other good polaris forums that might be able to help? thanks
Old Nov 20, 2007 | 12:34 AM
TLC's Avatar
TLC
96 500 Sportsman carb.
It looks like a butterfly carb not a slide carb ,but both would use the throttle to open up the carb and a return spring to close it. I did not know the vacuum of the engine operated any thing in the carb.[img]i/expressions/face-icon-small-confused.gif[/img]
In the above link what part are you moving by hand? Is it #35 "Valve Throttle?
Old Nov 20, 2007 | 12:46 AM
I am pushing up the slide with my finger, I am sure that the slide is operated by the amount of vacuum from the motor, The carb also has a butter fly that is operated by the throttle,
Old Nov 20, 2007 | 01:31 AM
TLC's Avatar
TLC
If it has something to do with the engine the first thing I would check is the Exaust lobe, It should be same height as the intake lobes.
Old Nov 20, 2007 | 09:51 AM
94harley's Avatar
The throttle cable opens the throttle plate allowing vacuum to pull on a diaphragm on the top of the slide. If the diaphragm has a cut, or loose from the slide it could be doing exactly what you are saying. Pull the carb and check the slide assy.
Old Nov 20, 2007 | 01:51 PM
Thank you I will look at that
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
