Help 1997 Scrambler 500 rear brake pedal
Old Nov 25, 2007 | 07:48 PM
mmonh's Avatar
Default Help 1997 Scrambler 500 rear brake pedal
If anyone can help
I have the 1997 Scrambler 500
I saw on the old posts to blead the caliper
I have done that and the rear brake works fine with the handlebar brake handle but has nothing on the foot pedal
When applying the break with the handle I do have pressure in the foot pedal but it goes down
The 1997 has only 1 bleeder and have bled them a few times
Old Nov 27, 2007 | 02:32 PM
08Renegade500's Avatar
Probably the master cylinder on the foot brake - Ive had to change it on both the scrambler and trailblazer.
Old Nov 27, 2007 | 03:08 PM
goodblasson's Avatar
If you play with that allen screw on the brake going into the master cylinder it should mechanically adjust the brake. Atleast 2 full turns on mine will adjust the pressure on the foot brake.
Old Nov 27, 2007 | 08:17 PM
mmonh's Avatar
The model I have 1997 has only 1 master cylinder that is shared for the front and back brake. The handlebar master goes to a block were it splits to the front and back brake. I dont have an allen screw for adjustment. I could use some help if someone has this type
Thanks
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
DeFox500
Jul 26, 2015 06:32 PM
Peter_
Jul 18, 2015 07:06 AM
