Help oil problems
Old Nov 25, 2007 | 11:21 PM
King B's Avatar
Default Help oil problems
2001 scrambler 400 oil pump went bad blocked off doing premix but so far i have tried two different ratios 50/1 and 40/1 when i tried 50/1 it ran and idled fine but lost power alot. today i tried 40/1 even worse no power but ran its not smoking like it would be running rich. when the oil pumped worked it hardley used any oil
can you run 60/1 or 70/1 it seems like it is bogging down likes its too much oil
Old Nov 25, 2007 | 11:45 PM
hoytultratec's Avatar
dont use 60/1 or 70/1 way to lean i thought 40/1 was correct ratio try searching premix ratio
Old Nov 25, 2007 | 11:50 PM
yup 40/1 if your having poor running issues sure your carb isnt dirty or a bad plug? this could be your problem..but definetly dont run anything like 50/1 or 60/1 or 70/1 . they need oil.
Old Nov 26, 2007 | 07:19 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i dont beleave it woulkd run too long before it seized the enigne w/ 60 and up to 1. 40 to 1 is a good mixture.
Old Nov 26, 2007 | 04:21 PM
OIown12's Avatar
This question my have an obvious answer, but why not spent $180 bucks and a little time to replace the oil pump versus blowing the thing up?
Old Nov 26, 2007 | 11:47 PM
King B's Avatar
The answer to your question is $$$ but when i went to the polaris dealer the mechanic suggested premix and said it works well,thats a crock. I talked to another guy today at polaris and he said to find out what in the oil pump went bad and i could get the part and repair it
Old Nov 26, 2007 | 11:55 PM
TLC's Avatar
TLC
Not sure how premix will hurt a engine, oil injection is just for convenience for filling up the gas tank.It does not provide better a oil supply to the motor in any way. I see countless of people disconnect there oil injection system on sleds without ill effects,should be the same with a ATV.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
