93 Trailboss wont run without choke on and bogs when running
Old Dec 1, 2007 | 05:22 PM
MYFIRSTTRAILBOSS250's Avatar
Default 93 Trailboss wont run without choke on and bogs when running
i just got a 93 trailboss and cant get it to run good. It will only run with the choke on and bogs down when trying to rev high. The carburetor has been cleaned good and engine has good compression. Ive read about the removing the black wire on the throttle override and tried it but nothing changed. I dont know if i removed the right black wire or not or if the carburetor is out of adjustment. At this point any help at all would be greatly appreciated.
Old Dec 1, 2007 | 07:00 PM
embler's Avatar
check the intake boot thing between the carb and motor. make sure its good and doesn't have any holes in it. friends recon would do the same thing and it turned out it was torn.
Old Dec 1, 2007 | 09:18 PM
ftwflh's Avatar
remove both jets and clean them
Old Dec 2, 2007 | 05:34 AM
I removed the jets and cleaned them. It runs a whole lot better except i still have to keep the choke on, but it doesnt bog but maybe 1 out every 5 times. I need to find the factory settings that might take care of it. Thanks for the Help.
Old Dec 2, 2007 | 10:18 AM
ftwflh's Avatar
Still sounds like you have a pilot jet stopped up.You have to be able to see good light through the center hole and all the holes on the side need to be clear
Old Dec 2, 2007 | 10:19 AM
hoytultratec's Avatar
right from the manual....air screw setting..3/4 turn out. didyou check the rubber boot for a air leak?
Old Dec 2, 2007 | 11:07 AM
The boot looks fine im going to adj the carb now. Also im trying to get the ignition to work I've got a Red, Red/White, Brown, and Black. wires cut on the key switch does anyone know witch wires go together
skittero
35
Mar 1, 2019 12:39 AM
chinkapin
Jul 14, 2016 06:58 AM
Ty Speece
Jul 2, 2015 04:59 PM
jayking232003
Jun 9, 2015 02:54 PM
FourWheelOverTwo
May 31, 2015 07:26 PM
