Couple of Recon Questions
Old Dec 5, 2007 | 05:08 PM
Ron In VA's Avatar
Default Couple of Recon Questions
I just bought a used 1998 Recon and have a couple of questions - I see that you have to push in the red button and pull the brake lever to go into reverse. Has anyone used one of the "red button eliminators" if you will, like what I see sold on E-Bay? Any comments on this? Also I would like to find an owners manual for the 1998 Recon. Even a copy of one would do. Thanks for the help.
Old Dec 5, 2007 | 09:27 PM
05 FOREMAN's Avatar
I bought one ...Best money i ever spent...I actually made some after i receved mine in the mail....its so simple youll kick yourself for not thinking if it before..Ill post some pictures of it if i can..
Old Dec 5, 2007 | 10:25 PM
MadRebel's Avatar
There's several things you can use that will work. I made one out of plasic with a dremel tool for my cousin's bike, then just used a couple of cable ties on mine, works fine. I bet a lead sinker or split shot crimped on would also work well.
No need to spend 10 bucks.
Old Dec 5, 2007 | 10:36 PM
Gimpster's Avatar
Or you can adjust your reverse cable adjuster to pull the cable tight.
----- Gregg -----
Old Dec 5, 2007 | 10:47 PM
05 FOREMAN's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: MadRebel
No need to spend 10 bucks.</end quote></div>
Your right i did the same ,And its works just as good.I just wish i knew this before i bought it..
Old Dec 5, 2007 | 10:59 PM
05 FOREMAN's Avatar
Old Dec 6, 2007 | 09:35 AM
Ron In VA's Avatar
Hey Guys, Thanks for the responses and the help. I do appreciate it. Ron
Old Dec 6, 2007 | 02:01 PM
hondabuster's Avatar
Just keep in mind why Honda made it that way. They didnt want the tires turning when going into reverse...it can really cause damage to the case and gears. Just make sure you come to a stop, before selecting reverse.
Kyle5050
Dec 13, 2019 04:25 AM
toonces
Oct 16, 2019 12:11 PM
peytonius
Sep 28, 2015 02:18 PM
MNatv89
Aug 10, 2015 02:20 PM
MNatv89
Jul 7, 2015 11:36 AM
