Polaris 90 no start
Old Dec 6, 2007 | 11:46 AM
happymech's Avatar
Default Polaris 90 no start
Can someone tell me why a Polaris 90 won't start. it quit while riding. It now has a new spark plug,new fuel filter,carb has been cleaned and recleaned. it gets lots of nice blue spark and good fuel to the cylinder
Old Dec 9, 2007 | 01:52 PM
harleypap's Avatar
Try a new spark plug and give it a small shot of starting fluid in the carb. If it try's to start then you have a carb problem. If it doesn't try to start then you have a ignition problem. Also check for vacuum leak. Hope this helps. Good Luck! Harleypap
Old Dec 14, 2007 | 11:06 PM
Djk's Avatar
Djk
chech the fuel lines, and check the spark arrestore, i've had a problem with mine on my 90 and it was falling off so we just squezed the metal part inside so it would grab the plug and stay, and make sure the plug is tight. And check the kill switch, there could be something wrong with it, and check your ignition, maybe theres something with the ignition. well theres some
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
1000gade
May 27, 2015 12:37 PM
