Testing voltage regulator
Old Dec 8, 2007 | 03:36 PM
Mada1855's Avatar
Default Testing voltage regulator
does anyone know how do a test on the regulator. I tested it for resistance an got nothing. I am not sure if I am doing it right.
Old Dec 8, 2007 | 05:05 PM
Gimpster's Avatar
Voltage regulators have Diodes in them. You almost need a ohm meter with Diode mode on it. A diode lets current flow one way and not the other.
Also you need the test spec for the regulator you are testing.
----- Gimp -----
Old Dec 8, 2007 | 06:30 PM
Mada1855's Avatar
1984 Honda 200es Big Red. The regulator is olny used for the lights and battery recharging right.. I am having spark problem so this shouldent be causeing any issue with that I guess.
I checked the regulator and I have a reading going both ways for one of the connections I checked. Should I assume that it needs to be replaced.
Thanks
Joe454
Nov 20, 2020 01:19 PM
Gwolf228
Feb 18, 2017 01:36 AM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
