Front wheel Aligment
Old Dec 17, 2007 | 11:21 AM
ewalden's Avatar
Default Front wheel Aligment
Hello Everyone,
I have a 04 650 v twin....I had to replace the tie rod on the right side because it got bent. Now that I have put the new one on, it's pulling to the right. Can someone tell me the easyest way to aline the front end.
Thanks for your help!
Ed 502-777-6831
Old Dec 17, 2007 | 11:51 AM
CATSKINNER's Avatar
The quickest and easiest way I have seen is to put a tie down strap on each hand grip and hook to the rear rack. Then stand behind and adjust the straps until the handle bars are pointed as straight as you can get them. Then stand behind your quad about 15' and see how the left rear tire lines up with the front. If the left looks straight, check the right and I'll bet it is pointing to the right. If it is out, adjust the tie rod end until the front lines up with the rear wheel. Double check both sides while you have the bars strapped and then ride it. You may have to fine tune it after that by coasting to a stop with the handle bars as straight as you can, then stand behind and see how they line up. Works for me every time.
Bratman2
Aug 6, 2022 01:42 AM
Jul 21, 2015 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
tporath
Jul 11, 2015 12:31 PM
