ETON 90 PROBLEMS
Old Dec 20, 2007 | 02:01 AM
Painterx's Avatar
Default ETON 90 PROBLEMS
Ok I thought I had everything fixed. I took it for a spin today. warmed it up for about 2 min.went for a ride down my 500 foot driveway turned around came back up stoped then went to go again and it diden't want to move.seamed like no power.I put it in the garage and about a hour I checked the compression and it was about 100 on a stock 90.now should I check it with a hot motor and see what the compression is?
Old Dec 20, 2007 | 07:56 AM
AIRMOBILE101's Avatar
I would compare compression readings hot and cold ,if the compression reading is worse when its cold, then you know you have a internal problem. If its a 4-stroke, check your valve clearance with the engine cold only.
Old Dec 20, 2007 | 12:27 PM
LT80's Avatar
LT80 Expert
Plugged jet?
Old Dec 20, 2007 | 02:13 PM
Paint , my sons KFX50 runs 170psi cold. check valve clearance(assuming its a 4-stroke).
Old Dec 20, 2007 | 02:18 PM
Another thing,if that bike is so equipped with an auto choke ,dump it and get another carb.
Old Mar 24, 2008 | 12:02 AM
MuDD4FuN's Avatar
We have an 2005 Eton 90R that was quitting when the throttle was pressed. Still being under warranty, took it back to the dealer and they said the problem was the ignition switch. Picked it up, it ran for a while and then it quit. Will not start at all now. Checked all wiring and checked the current which stopped at the CDI Box. From reading on the forums, decided to put a new CDI on. That didn't work. It will crank but no spark. What can be the problem?
[img]i/expressions/face-icon-small-confused.gif[/img]
"Always Ride With Safety Gear and Be Responsible"[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 25, 2008 | 12:58 PM
oldyeller's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Painterx
Ok I thought I had everything fixed. I took it for a spin today. warmed it up for about 2 min.went for a ride down my 500 foot driveway turned around came back up stoped then went to go again and it diden't want to move.seamed like no power.I put it in the garage and about a hour I checked the compression and it was about 100 on a stock 90.now should I check it with a hot motor and see what the compression is?</end quote></div>
Make sure your spark arrestor in the tail pipe is not plugged up....If thats not the problem it sounds like the engine may be too rich..How does the spark plug look?..Is the air cleaner clean?
Old Mar 26, 2008 | 01:51 AM
MuDD4FuN's Avatar
I found out alot since I was on here with my question. It looks like it is the AC Generator Assembly. I found a website that actually goes through a troubleshooter. For anyone interested, here it is.
http://www.anythingatv.com/Tec...l/Troubleshooting.htm
Just click on what is ailing your ride.
Keep On Riding[img]i/expressions/face-icon-small-cool.gif[/img]
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Ramman1
Jun 16, 2016 09:07 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
